I need help configuring my 1762sc-OF8 output module
CJlikesCHAIRS
May 2015
Nope
65
Hi, I am fairly new in the PLC industry, and my latest job for me to complete is to test a panel with a single output module (Spectrum Control 1762sc-OF8) with my ML1400. I have everything working, except this output module. After looking through this manual and adding all the rungs to correctly configure it, I receive an error code (F002 in HEX/BCD, yet -4094 in decimal). I have been working with one of our programmers to see if we can solve the problems I have been having with no such luck.
Any advice will be amazing as I spent all day yesterday trying things that didn't work.
Thanks for the reply guys, I found my error.
I put test bits in to see which lines were working and which weren't and saw that my o:7.0 and o:7.1 bits were receiving other numbers that should not be there. So I came to the conclusion that other lines were being solved before the calibration rungs had finished.
So I moved the calibration rungs to the very top of my main lad. They get solved before everything else and it works perfectly now.
I'm having trouble configuring my 1734-OE4C 4ch analog out modules. I've read the docs but details on configuration is sketchy at best, at least...
3,631
I am trying to get a micrologix 1100 to communicate with my pv+ 400. I have quite a bit of experience with rs logix 500 but never have had to set...
3,957
Hi folks...I need some help getting a 1769HSC configured correctly. Here is what I need, in specific: I will need to use a directional counter...
1,533
30
I'm fairly new to Rockwell software, I've had some basic training in the past but nothing too advanced. My company and I use Reliable products for...
342
