Need help configuring 1769-HSC with ML1500
ryanar15
Jan 2006
Ohio
Hi folks...I need some help getting a 1769HSC configured correctly.
Here is what I need, in specific: I will need to use a directional counter, and I also need to get an active RATE count (not just a number of counts) to be dropped on to the serial port (eventually). Right now I'd be happy with a valid configuration.
I followed the instructions in the 1769HSC Programming guide and was able to monitor the CurrentCount/CurrentRate words, however when I tried to configure it past the example given in that guide, I get nothing but faults.
If I set the Update Time to anything other than 1 I get a fault. I've tried 10, 20, 60 and 100. All faults (no other parameters changed).
If I set RPM Scale Factor to anything other than 1, I get a fault. I've tried 60. No other parameters changed.
I'm using an ML1500 with the 1764LRP processor and the -24BWA control unit.
Hi, I am fairly new in the PLC industry, and my latest job for me to complete is to test a panel with a single output module (Spectrum Control...
1,767
I'm having trouble configuring my 1734-OE4C 4ch analog out modules. I've read the docs but details on configuration is sketchy at best, at least...
3,626
I am trying to get a micrologix 1100 to communicate with my pv+ 400. I have quite a bit of experience with rs logix 500 but never have had to set...
3,954
27
I'm fairly new to Rockwell software, I've had some basic training in the past but nothing too advanced. My company and I use Reliable products for...
342
