Help For A complete Beginner?
Leonardo_2010
Oct 2010
North England
Hi There,
Wonder is someone could help me please? I have virtually no PLC experience and therefore am a little bit stuck here. I have a Panasonic FPX and the programme in it is wrong. I do have the correct version of the programme and also FPWIN to download it.
I have also two recipe programmes as well to download. Normally I get another company to download this into the PLC, but the chap is away on holiday and I really neeed to get this thing downloaded. Could someone please tell me how to completely reset the PLC. and also then when I download the programme, do I put the main programme in, followed by the recipies or is it the other way round? do I need to change the switch to prog mode on the front of the PLC while I do this?
Any help would be much appreciated..... thank you all
Welcome Leonardo, Welcome to the forum.
I have never worked on a Panasonic PLC, but in general terms when you download a program to a PLC the old one get overwritten, so you will have the new program running after that, no reset is necessary.
But I wonder what is the 2 recipe files you are referring to? :unsure:. It is a set of data to be transferred to the HMI?
May be somebody here will help you,
or better wait till the guy come back
or hunt for a "backup guy" for your needs.
Regards
Update and more confuddlement
OK, Bit of an update...... I decided to stop being a wuss, and downloaded the programme first, followed by the recipies..... ok, so after some messing about, I find 2 things... One is that the system does not behave the same way as the other machines we produce (the ones that had the programme downloaded by our holidaying software guy...)
One function seems to be missing.... So I had a brilliant idea, I would upload the programme from one of the functioning machines and put that into the new machine..... but when I tried to upload the programme, I got an error in general memory and could not upload it....
Also I get another message, saying that the PLC is different to the one that the PLC is different to the one that the programme was written for, DoI want to change the values.... I can do this, but then it fails to download.....
The PLC is the same as the others, they were all ordered together in the same batch and are the same... Panasonic FPX C14PD but for some reason this one is giving different size of memory and different version of FPX....
I copied the original programme and re-named it so that any of my messing about would not change the original programme on my PC... I can at least go back to the original if need be....
I wonder if the question remains.... is there a way of resetting the PLC memory back to factory default and clearing all registers? eeprom memory etc?
Just a thought and an update....
Response to Chavak
The recipie files are for..... something.. :)
I am not sure, just that my programmer says they need to be downloaded...... Not sure what they refer to or what they do....
Any help for a Beckhoff PLC that does not start up correctly the first time? The system will lock up, stop responding at times, requiring me to...
1,791
Hey everybody! My name is Stone McVeigh from Detroit Michigan. I am pretty new with PLC's and I am looking to grasp a better understanding of it...
21
9,527
Does anyone have have a suggestion for a Allen Bradley family of HMI's tutorial. I am doing a lot of work at a plant that has a variety of AB...
4,250
Disclaimer: I browsed the forums and must say this is far outside of my knowledge in every facet. I work in Exhibit Design and have no real...
3,093
HI everyone, i am new to Siemens plc programming and i am in need of some help. yesterday we had an S7-1200 CPU 1214C fail to turn on an output to...
82
