Help for Guard Logix CPU L71S
Ali Raza
Oct 2016
Lahore
Help required For Guard Logix CPU L71S
We are facing following problems for gurad logix
1) How we can edit the safety Program and safety tags
2)Could not change the Safety Modules Properties
Is there is any procedure for that or it is software end Problem using Studio 5000 standard edtition
After that we send Empty program with Existing Hard ware then At online it gives I/O Not OK communication not established bw EN2tr to AENTR and its safety point ios
You have to unlock the safety to change anything safety related....in the upper left of logix while online does it show locked or unlocked?
You can't modify any safety programs using Logix Standard Edition. You will need Full or Professional edition.
And, as robertmee said, you'll have to have the safety unlock password too.
Hello, I'm adding an Allen-Bradley SensaGuard door switch (440N-Z21SS2H) to a small existing machine to drop out pneumatic function when the...
948
Hi to the forum. I have a logic problem which is confusing me. From my sketch I have seven conveyors that I control using a twido PLC via canbus...
19
5,597
30
Hi all, hope you are having a great day, I am in need of your help to create a AOI or program that does this kind of job: I have a IO Link...
20
292
please help me . I have to make this ladder diagram and I can’t figure it out :(
351
