hi, everybody
I am a new in this field. I have question and hope get expert help!!!
when I use panelbuild32 set a start botton and I set write tag as start and address I:2.1/1 , I edit tag by useing Controller Address.but when I validate, it say: illegal address reference. what's wrong? according to instruction:"
Controller Address
When Controller Address is selected, the PanelView initiates communications directly to the logic controller addresses. The PanelView reads data from or writes data to a PLC-5E, SLC 5/05, MicroLogix/FlexLogix/CompactLogix through a 1761-ENET-ENI module, or ControlLogix 5000 through the 1756-ENET/B or ENBx module. The controller is pre-configured in the Terminal Setup/Communication Setup dialog. You must specify the Node Name of the target Ethernet node for read or write operations.:
it should be when I use I:2.1/1 in slc ladder logic, here I should use same address( I:2.1/1)
hope get some advice!
Controller Address
