Help identifying an Antique
I've seen something resembling that on an 80's german manufactured machine. This "PLC" was controlling a drum with a knife that cut sheets of paper in a paper mill. I belive it was basically a rack slot computer made up by different modules so you couldnt program it like a PLC, i think i must have been programmed in either C or assembly.
Spot on ojz0r, it is controlling a paper sheeting machine from the late '80's. And yes, its all in assembly language. The DC Drive controller cards are pretty specialized I think. In addition to this mystery controller, there is also an Allen-Bradley PLC 2, both interfaced to a DOS PC as an operator interface. A dinosaur times three!
Facinating. Is it a Jagenberg machine? I think the control unit was done by a company called micromatic/mikromatic* or something similar. I tried to find if i had any photos of the control unit but it seems i never photographed it sadly. I havent worked there since the beginning of 2012.
That machine was upgraded to Siemens S7 in the early 2000's. They were communicating in ASCII over serial, cant remember if it was rs-232 (most likely) or rs-485.
The DC drives was BBC but had some markings of ASEA/ABB so it was probably around the time of the merger.
i don't know what it is...but my first thought was early japanese PLC ?
e careful before powering down.
try to see if there is any back up media onsite (probably cassette tape or 5 1/4" floppy from that era i'm guessing, even if you do find this its unlikely you can recover unless the interfaces are also there)
possible problems to be aware of
  1. if its always powered then the backup battery for program may be low and you could possibly lose the program
  2. older equipment power supplies can fail once powered down and then powered up, the inrush current can sometimes cause them to fail ( i have had this manyb times over my 40+ years) mainly with older VSD's and Switchmode power supplies
  3. the same as above for CPU and I/O cards
Good guess. The 'X' and 'Y' are give away indicators.
At a minimum, the I/O cards are non-US, but, yes, it does look like a VME package.
So after further investigation, it appears these are custom cards. The manufacturer of the sheeter has their name and I presume a card number (part #) that they or the subcontractor who actually made the cards assigned. I suppose starting from scratch would be best, but it is a huge project for the small company that "owns" the thing. Unfortunately, with out understanding how the whole system works, it would be all but impossible to try to do it "piece-meal". Houston, we have a problem...
So after further investigation, it appears these are custom cards. The manufacturer of the sheeter has their name and I presume a card number (part #) that they or the subcontractor who actually made the cards assigned...
A lot of manufacturers will rebrand their product if you buy in quantity, I have seen where that quantity can be as low as 2 pieces.
Chances are it is a (sort-of) name brand controller the OEM of the machine had their name put on.
Hello, I'm looking for a source for the white connectors in the picture below. This controller has 6.3mm spade connectors potted into it in rows...
1,434
Hey guys I have a picture of a PLC and I am not sure which model it is. It looks like a Point I/O but that's all I got.
3,103
I've got a picture from one of our customer and I cannot identify one of the module (PLC5). It seems to be serial communication, 4 port. I did a...
1,976
Need help identifying the make/model of this valve position sensor, there are no definable markings, it came off of an air actuator for a liquid...
2,014
Can anyone give me the part number for this module? I am looking for the data sheet on the 25 pin ports. thanks
1,787
