help me change to LAD these codes
smiles
Oct 2006
DaNang
36
I just start with S7300, here is the code I saw in help document about timer
01. A I 2.0
02. FR T 1
03. A I 2.1
04. L S5T#10S
05. SE T 1
06. A I 2.2
07. R T 1
08. A T 1
09. = Q 4.0
10. L T 1
11. T MW 10
12. LC T 1
13. T MW 12
I look up, compare o_O but not find out the ladder for codes from 10 to 13, could you save a little time help me !!!
Thanks !!! :)
Hello Smiles;
03. A I 2.1
04. L S5T#10S
05. SE T 1
06. A I 2.2
07. R T 1
08. A T 1
09. = Q 4.0
10. L T 1
11. T MW 10
12. LC T 1
13. T MW 12
Tranlstes to:
Hope this helps,
Daniel Chartier
That helps much !!!
In the library, I also see the term timer coil like SP, SE .... I remember that in S7200 not have this term, do you know what are they used for, stand for output Q of timer ???
Hello smiles;
The following 2 rungs are equivalent as far as logic is concerned:
Just check the online help for more details.
But you have less functionalities if you use the coil form of the timer, no reset bit, no binary or BCD countdown values available.
Hope this helps,
Daniel Chartier
how can I make it right
My coding is about when your input I0.0 =1 then you transfer the content 2#1111111 to MB0
begining
A I0.0
L 2#11111111
T MB0
not work
Second way
A I0.0 (or L IW0 then compare with 1)
L 1
==I
JC test
test: L 2#11111111
T MB0
still not work :oops: (MB0 always contents 11111111 before I turn on I0.0)
what wrong with my code ???
Try this:-AN I0.0
JC Test
L 2#11111111
T MB 0
Test:
The load command in siemens is unconditional i.e. it does not rely on the RLO to carry out this command
Hello smiles;
What in your program resets the bits in MB0?
Once they have been set, they will remain set...
A suggestion: start by moving 0 to MB0, then test your original logic.
Hope this helps,
Daniel Chartier
Hi Daniel !
You say Move instruction, I did it in LAD and run well, change to STL, this is the last :)
A I 0.0
JNB xng
L W#16#FF
T MB 0
xng: NOP 0
Thank you !!!
Hello, I've got a program from a customer for a Micrologix, but can't open it without upgrading to a newer version of RSlogix 500. Could someone...
1,034
Hi guys....first post here. It's been about 6 years since I worked heavily with PLC's and automation, but I'm getting back into it. I was hoping...
20
3,656
I've been working on a fairly large project for the last couple months and have come to a road block for the last week. I've spent countless...
7,139
Hello in a factory uses a allen brdaley servomotor and controller which became obsolete , I want to know the criteria for the choice of a new...
1,601
Dear Friends, I hope all are going well. Anybody can help me how to set System Date &Time (PC) as PLC Date & Time in FTView SE. Is there any VBA...
2,223
