Need help with rev change please
Jan 2017
Kentucky
Hello,
I've got a program from a customer for a Micrologix, but can't open it without upgrading to a newer version of RSlogix 500. Could someone please help convert it to a revision I can use? I've attached the file and an image of the revs I have available in RS500. Any help would be greatly appreciated!
Thanks.
  • GLUE MACHINE - RHINO MACHINE 7.zip
Changed it to a Series A, seems to check out, there are two shorted branches being used to jumper out some inputs.
No problem, I ran both programs through the RSLogix Compare Tool and it returned a difference in the processors (obviously), but there are also some extended Ethernet options on Channel 1 in the original project that aren't available on a Series A, but they don't seem to be anything groundbreaking, just some disabled protocols.
Hello everybody Ok I can't get this . I want to know if I can use same input for either direction for./rev. And can...
63
11,493
45
I'm fairly new to Rockwell software, I've had some basic training in the past but nothing too advanced. My company and I use Reliable products for...
345
171
Good day all! Can someone help me with the procedure to update Beijers E700 firmware? The Panel I am working on is firmware 2.04v and I would...
74
