help me understanding this PLC Statment list code
nasir130
May 2009
karachi
call #v10A1
enable :="valveDB".v10A1.Enable DB24.Dbx0.0
Interlock :=
open_feedback := "mapped-do".D0_1.V10A1 DB104.DBx0.0
close_feedback := "valve DB".V10A1.Valve_off
Reset_valve_fault := "valve DB".V10A1.Reset_valve_fault DB24.0DBx0.4
valve_fail_time:= "valve DB".v10A1.valve_fail_time DB24.DbW2
Flash_trip:=
valve_on :="mapped-do".D0_1.v10A1 DB104.Dbx0.0
valve_off:=
open_ind:=
close_ind:=
time_out:=
mode := "valve DB".V10A1.mode DB24.DBw8
status:="valve DB".v10A1.status
valve_fail_count:= "valve DB".V10A1.Valve_fail_count
Have a look in the declaration(Top) area of the block you copied this code from, I would say #v10A1 is a FB/FC called in the STAT area.
If you right click on #v10A1 and select CALLED BLOCK/OPEN you will see the code from this call (if im correct :p)
Hi, To give some context of the situation and why I'm posting. I started a PLC module as part of a general engineering course last year and the...
2,039
I'm trying to understand how the PLC will scan this "For" loop. will the "PhoneNb" variable not increment until all instructions within the "For"...
1,666
Took a new job and the controls schemes are fairly old and I'm used to Allen Bradley and Siemens. I'm looking to replace a pair of Superior...
114
Hello Team, I am desperate for some help with an assessment I have as part of a Level 3 general engineering course. I am in a role that is much...
355
https://imgur.com/a/kKPtzyP We are making improvements to these motor controls by replacing these old resistor banks and DC generator with DC...
1,789
