Need Help In Understanding how PLC will scan this.
damica1
Aug 2015
Illinois
839
I'm trying to understand how the PLC will scan this "For" loop.
will the "PhoneNb" variable not increment until all instructions within the "For" - "End_For" are complete? Or how will it scan this? Ton_4 is 3 seconds and Ton_5 & 6 are 1 second timers.
if FBEN THEN
For PhoneNb := 1 to 2 DO
TON_4(AWT_4.Q, Time2); R_TRIG_8(TON_4.Q); AWT_4(R_TRIG_8.Q, TextModeEnable, EnableTextMode);
TON_5(AWT_5.Q, Time1); R_TRIG_9(TON_5.Q); AWT_5(R_TRIG_9.Q, PhoneChannel, PhoneNumber[PhoneNb]);
TON_6(AWT_6.Q, Time1); R_TRIG_10(TON_6.Q); AWT_6(R_TRIG_10.Q, TxtMessage, TxtMessageData[EvtMsg]);
END_FOR;
SendDone := TRUE; (* Function Block Done Bit *)
END_IF;
https://imgur.com/a/kKPtzyP We are making improvements to these motor controls by replacing these old resistor banks and DC generator with DC...
1,789
I get so confused by Rockwell's licensing structure. I have two PC's that will be running the same SE application. Can/should I run this as...
1,841
Good Afternoon , I'm sorry. But I'm struggling to understand this combination of integers in this MOV , and really anywhere else this scheme...
1,613
Hi folks, I am wondering if you guys can help me understand what the intended operation was for some logic that relates to the operation of the...
1,636
Good afternoon, I want to understand this old piece of logic I found in an old program (RS Logix 500 on SLC 5/03). I have two rungs here in a...
3,671
