Help me with a preset time value ?
Of course, without DB-blocks PLC can't write data values of program blocks anywhere and PLC will go stop mode.
thank you very much lare,
finally it's worked
really i am happy
at last i want to thank everyone replied on me
I'm sorry if you feel bored of my questions i am still learning
No problem. Siemens isn't easiest PLC to start with. Siemens PLC programg consist of several small parts, which you have to download separatly to PLC. (DB, OB, FB, FC blocks and hardware config)
On other PLC platforms these all are in one place, and changes are downloaded at one time.
It have cons ans pros. Usually you need to compare offline and online blocks to see if all changes are donwloaded to Siemens PLC. Red fault light is easy to get on ;)
Also on Siemens you can download PLC program which have error to PLC and it shows error only after download.
On other PLC platforms it is usually not possible, because program is checked before downloading to PLC.
I will note that the newer TIA Portal software makes a lot of those things easier. It compiles the program before downloading, to try to prevent most syntax errors. It also downloads the whole program, making it far harder to only download part of it on accident.
Hello, i need some help with attaching a preset timer value to a timer. This is the scenario. i have a conveyor system that transports 18...
7,950
Hi pal, Need some enlightentment about the timer counter's preset value. The preset value changes to the default value whenever i am in the online...
5,073
Hello I usually represent all my time delay in 0.001sec inside the hmi but know i need to enter values ranging to 2o minutes meaning 1200...
3,645
Hello everyone. Could someone please assist me? I am using Citect version 7.2 service pack 5 and Windows 7. I have created a project...
Hello, I'm not sure if anyone can help me. I made a big mistake by pulling out the battery to swap it with the machine turned off, and as a...
