Help Needed with repeat cycle program
av8r
Oct 2004
I have a small problem with getting my machine to repeat a sequence if a switch is closed.
Basically this is a mcahine which takes a basket of product dips it in a coating while spinning at a low rpm. It then pulls out of the coating and spins at a higher rpm. Right now the program is set so it will spin forward and if there is a switch closed it will spin in reverse. The problem arises at this point. I need it to spin forward again and then reverse again when an input is given. I have labeled the program to the best of my ability. I got the machine used and we are trying to update it. I guess i am saying that i am not the original author of this program and i am having a tough time figuring out the logic behind some of the logic.
Attatched is the program.
Thanks in advance.
I have an old PLC (circa 2007) consisting of Telemecanique/Modicon/Schneider Electric devices. The system has developed errors and unfortunately...
265
Hi I’m after some help , I have a plc program with a baumer verisens vision camera attached I have got the signals working ect but I have an...
977
Hi all, We are facing synching issues with redundancy module, where the Primary is ending up with disqualified secondary. Normally this would...
641
Hi all, I have got this machine that needs to be up and running soon. This machine has Schneider's Controller and I/O modules, 3 vfd's, 2...
925
Is it possible to write to the high speed counter function file "high speed preset" on an AB micro 1100. I have the HSC set up with a MOV...
1,104
