Help please with Mitsubishi GX developer
pacunnin
Oct 2010
ireland
Hi there, PLC is all brand new to me so please bear with me. I am using GX developer FC software and i need to have an LED flash on for 2 secs then off for 2 secs and repeat until the enable input is de-activated. Any ideas as im at a loss how to get the repeat. thanks
Here's a clue then. 1 input, 1 output, 2 timers set at 2 seconds.
That's all you need. Show us how far you have got - and we will help you.
i started with this but dont see how if will continue to run
I originally did not use set/rst and had 2 timers
thanks
You have tried which is good on this site (and rare) so you need to get perfectly clear in your mind the sequence of events you need to program.
You turn X0 on and you want Y0 on, after 2 seconds you want Y0 off while X0 is still on
Code:
-|X0|---------(Y0)
So you need a timer set at 2 seconds to turn YO off
Code:
-|X0|--|/T0|-------(Y0)
     |____________(T0 K20)
At this point T0 will turn off Y0 after 2 seconds while X0 is still on.
Now you need another timer to time the 2 second off period
and this timer to reset the sequence
You have a go from here
HOW to communicate with OPTIX and Mitsubishi's Q Series PLC?? PLEASE HELP ME
80
Hi everyone, I'm new to ladder programming and I may have been too ambitious thinking I could do a full plc program by myself. My father has a...
62
14,939
Im running two machines with these units. I had to power one down yesterday to do some work on it and when I powered it back up the plc isnt...
2,454
I have a problem with a Mitsubishi QnA series that happens once every 28 days at exactly 4:30 in the afternoon (at least for all of 2010). I am...
2,237
please help me in mitsubishi plcs i have one of it its type fx1s-20mt put i dont have a soft wear and aconection cable how can i take them please...
206
