Help S7-1200 programming actuator
jaseplc1
Jun 2015
quebec
Hi I need helpp in writting my PLC program:
I m new in siemens PLC programming and TIA PORTAL
here is the topic:
I have to write a PLC program to command an actuator which move between two limit switch END_FWD_sW and END_BCK_SW
fOR THE PROGRAM I HAVE:
lIST OF HARDWARE:
1 S7-1200 CPU 1212C AC/DC/RLY 6ES7 212-1BD30-0XB0
1 REVERSING CONTACTOR WITH LED
1 STARTER
1 POWER SUPPLY
List of Inputs :
1 FWD_BUTTON to send the actuator FORWARD until it reach the limit switch END_FWD_SW
1 REV_BUTTON to send the actuator BACKWARD until it reach the limit switch END_BCK_SW
1 E_STOP_BUTTON to STOP THE actuator at any time
1 AUTO_BUTTON to put the system in auto mode so that the actuator could move alone between the two limit switch
from the END_FWD_sW until END_BCK_SW and so on in the two send of direction
1 MANUAL_BUTTON to put the system in manual mode
1 INPUT_FWD_SWITCH which tell me that the end forward position has been reached
1 INPUT_BCK_SWITCH which tell me that the end backward position has been reached
List of Outputs :
1 OUT_FWD for the forward move
1 OUT_BCK for the backward move
And maybe another output or Input if you think it will be necessary for the program
I also have to use a timer when i stop to avoid fault or brutal colision in the actuator
I also have to count the number of time the system will be used in auto mode or manual mode
to do that , I have to count everytime the actuator hit the END_FWD_SW and then hit back the END_BCK_SW , this will be one time, and so on
I was thinkind about using DB instances fot the motor to get all the count and etc... but I have no idea where to start.
I have always create the project in TIA PORTAL V13, but dont event know.
ANY HELP PLEASE ???????????
I attach here the actuator and what i have write for the program. And How I have use my variables and use the DB instance
My program is not functional, SO I NEED HELPPPPP PLEASE;)
THKS YOU
actuator_schematic.png PROGRAM Page 1.jpg PROGRAM Page 2.jpg PROGRAM Page 3.jpg
Hi all, I'm in the process of upgrading a PanelView1200 HMI program to be developed in FactroyTalk View Studio. The filetype for PanelView 1200...
283
Good, Code Totalizer: IF ( Hour = 23) and ( Minute = 59) and ( Second = 59) THEN totalizerDay_previous : = totalizerDay; totalizerDay= 0; End_IF...
1,569
I have 3 control panels made by an OEM, they are all identical and have a Siemens S7-1200 PLC with a Siemens CB-1241 Modbus card talking to 2...
4,544
Hi,I need to build a PLC panel with a CUP & I/O cards, the panel to be communicated with a remote (500 meter away) extension module station. I...
2,545
Hi everyone I am completely new to using shift registers and am a bit stuck, my shift register works as should, it is for an overhead conveyor...
55
15,625
