Hello, I need some help adding a project to an existing PLC and HMI. We have a SLC 5/03 controlling a filtration systems. I will like to add a current transducer (4- 20 ma CT) to each of the three phase legs of two different pumps for monitor the Amps for PM purpose. This is the deal, I don’t want to use six analog input. I want to use a relay for switch one pump at the time and that way I use just three inputs.
Now. I want to record the maximum amps reading in the HMI for each pump and in every PM reset the Amps reading in the HMI.
The questions is, What instruction do you recommend and how? I got the HMI part.
