Help with energy saving program??? pls
Persephone
Aug 2021
there
Hi im doing a energy saving program for a lamp. And basically the instructions are to turn off the lamp if is not being used ....... but with no sensor.
the lamp have to turn off if one cycle of work have ended (this machine make the weld of a part of the car).
i need help to put that instruction, i have made the "waiting" with a TOF timer but i dont know where to put it in the main program of this weld cycle.
In ladder logic, the "where" something goes is not too important. Every rung is executed many times per second. You could put it near other code that is related to the lamp to keep things tidy. One thing to watch out for with a TOF is what happens when you first start up the PLC? Does the TOF.DN bit start high or low?
How will the PLC know the one "cycle of work is done" condition has been met?
Does the PLC control the welding process?
42
Hi all, hope you are having a great day, I am in need of your help to create a AOI or program that does this kind of job: I have a IO Link...
22
342
please help me . I have to make this ladder diagram and I can’t figure it out :(
355
Hi Everyone, i was hoping for a little help with this module. i have data that needs to be read from a different plc through the Modbus plus...
233
Hello, I am trying to replicate a piece of logic on the PLC5 onto an SEL RTAC. I am using ladder on SEL and FBD. I am having issue on the ladder...
240
