turner15429
Hey guys, I'm programming this stepper motor to go back and forth at two set angles. After programming, I realized that my program only works when both angles are the same. Example 90 and 90 for a total of 180 travel back and forth. I have pictures attached that better explain my program attached. I'm just having issues thinking of a logical way to change my program to get my desired output I'm unsure of what equation I can use... Any help is much appreciated
some insight to my tags and program:
df11 is an angle set by HMI
df10 is an angle set by HMI
sh3h is go to home command
fl is feed to length command it goes to x many steps regardless of position
fl- is opposite direction
