Help with logic
paulB
Apr 2003
171
Hi everybody.
On one of the machines operator have to perform visual quality checks on the first three parts. I am trying to automate results of these quality checks. These results are PASS, FAIL, NOT COMPLETE. SLC 5/05 and Panel View is used. There is the quality checks screen created in Panel View. It has indicator dispaying part number (1, 2, or 3) and two momentary pushbuttons YES(Pass) and NO(Fail) with the Write Tags and Indicator Tags. After operator inspects first part he presses YES or NO pushbuttons. As result in the PLC registers N250:71 getting certain value. After that part number indicator should advance from 1 to 2, and Panel View is ready for inspection second part. After second part is inspected indicator advances from 2 to 3 and is ready for inspection of third part. After third part is inspected inicator goes from 3 to 1 and machine is ready for the next inspection cycle. In my program Panel View pushbutton Write tags are sealed by Indicator tags. I cannot come up with the logic which will unseal these pushbutton after first part is inspected and is ready for the next part. I am attaching my program. Please, take a look and help me.
Thank you.
PaulB.
[attachement]
See if this helps... Not sure exactly what you are asking but this should reset most everything when all three of your done bits are true. Let me know how it works...
Good luck...
Hello, I am trying to replicate a piece of logic on the PLC5 onto an SEL RTAC. I am using ladder on SEL and FBD. I am having issue on the ladder...
241
Working on project will update after it is completed.
358
Can someone help me piece this problem together. I have a lot of it down I think but cannot seem to get it right. Probably an easy one for most on...
305
Hi everyone, I'm working on a project that involves using a Keyence LR-X100 sensor in Studio 5000 V35 ladder logic to determine the object's...
681
Hey. I am new to PLCs and LogixPro. A friend and I have been trying to build this diagram and instructions using LogixPro500. Could anyone help us...
1,293
