Help with Mitsubishi FX3u-48M and FX3uENET Module
asimpswi
Apr 2010
san antonio
I have a FX3u-48M PLC with a FX2n-16EX card, FX3u-4AD and then a FX3u-ENET I am trying to put this processor on our network I have configured the ENET card with FX Configurator-EN I want to be able to troubleshoot over our network for remote support. I can use a cmd prompt and ping this processor and get a response but none of the Mitsubishi software (GX- Developer v8.78G, or FX-Configurator-EN) can connect via Ethernet. Status lights are as follows run is green Init. is green and 100m green, SD and RD blink every so often. I have the ip, gateway and subnet all set for out network and like i said i can ping using cmd prompt and get 4 responses I can unplug from network ping and get no reply so ip is correct.
When i do a connection test via Ethernet i get this error "cannot communicate with the PLC. Execute again after checking the connections with the PLC. <ES:01808201>
Any help would be much appreciated I have about 40 processors i need to add to our network.
NO one? My partner can connect with a crossover cable I cannot something is not right in my software i guess i have tried my main computer and my back up. Is there some setting in the software that must be changed to communicate via tcp/ip?
hello everyone I'm new to this PLC mitsubishi FX3U and fx 4AD analog module I'm using a ultrasonic sensor 4 - 20mA to measure liquid level in tank...
4,823
Hi can you help, have a book stitching machine with collates pages in 8 stages. I have installed a camera system that will give an input to...
24
1,903
Is there an output or something that is similar to a screen saver, but you can use in the plc to know when the user is actively using it...
505
I have a Mitsubishi FX2N-64MR-UA1 processor. The 1st analog output card is an FX2N-4DA. It requires 24VDC power. That card is obsolete. The card...
1,586
