Help with NAIS FP1 programming
PLCRookie
Dec 2005
I'm right here...
305
I have a NAIS FP1-C40 that has been pulled from storage after many years. Needless to say that the battery is dead, no program. I called the OEM, and all I could get were 5 diskettes (3.5)and a "good luck". It appears that I will (obviously)need to get a new battery, as well as a programming cable, but I am unsure as to what type of cable is needed. I have been to the Panasonic web site, and it seems that I will need a 232-422 converter to hook my laptop to the PLC. There is also another cable mentioned, to go to the "tool" port. I have FPSoft V1.06B. Will this software run under XP? Any help greatly appreciated
http://pewa.panasonic.com/acsd/tech/cad/cad_PLC.html#fp1
Above link has all software you might need. You will also need two cables - one is AFP8550 RS422/232 adapter, the other connects to the tool port as you mentioned. I tried making one, but ended up ordering.
I'm using FPWINGR V2.4, communicating with an FP1-C40. That works fine. The problem I am having is communicating with an expansion unit FP1-E40. I have tried several variations of allocating addresses, but cannot find any docs instructing on this. Seems NAIS is related to AB in the "too much information, not enough useful data" department.
Let me know if you need any more help on this.
Jimmy
PS - anyone know how to allocate addresses that E40?
Thanks for the replies. I used the free downloader software for the PLC program, everything OK. Now for the dead HMI................. Thanks for all the replies
NAIS FP1-C14 Programming Cable Pinout diagram
Dear All,
Anybody have the the Pinout diagram for NAIS FP1-C14 Programming cable?
I have learned that its RS422 Communication to program the PLC. I have RS232 to 4wire RS422 Converter that I use to program Mutsubishi PLC.
Waiting for help from any one.
Thanks in advence.
Mannan,
Chittagong, Bangladesh
Dear all,
I deal with a NAIS FP1-C40, which was powered off for 4 months, with the 3V battery dead.
Obviously, when powering back, we lost the dedicated program. We have no suport from the installer or manufacturer, and any of the links mentioned above are still active.
Would someone could provide:
- the FPWINGR V2.4 software
-the wiring for the RS232 cable?
Many thanks for any helper :) :) :)
Email available for Wetransfer if needed.
Bertrand
Dear all,
Bertrand
Can you help with programming Nais Fp 1c40 ?
Thank for Any help
Hi, I'm new to this Forum. Can anybody help me with following. I want to reprogram an old Matsushita (Panasonic) NAiS FP3 PLC. CPU model no...
3,132
Dear all, I am a student. Please share on the right wiring of the attached PLC (Panasonic Nais FP1-C40. I am using AC connection and able to...
3,637
trying to find a store front I can go to in hopes of purchasing an programming cable for Panasonic PLC. The cable part number i have is FP0-PWS...
6,089
Good morning all: I have programmed extensively with many AB packages, many Omron packages, Idec, TI, but never Nais. I'm using FPWin Pro4. I'm...
3,448
Hello, I am trying to work with a nais fpo-c14rs and am using FPWIN PRO 5. I have slowly worked through the "on disc tutorial", and have problems...
4,130
