help with PID control
You guys did pick up on the fact that he is dealing with a pair of air-driven process control valves, right? He needs 4-20mA signals going to them. And I suspect his prof. will be REALLY p!$$ed if he changes those valves out for the discrete valves you are talking about.
Keith
Keith
That's the temperature control. The level control is just a solenoid valve.
Or did I miss something? Show me.
Still working on this. I tried the level control using Mickey's logic and it works, but I had to make the GEQ's into LEQ's since the solenoid is closed when energized. Also it clicks on and off like crazy when the level is on either end of the set point, so I need to add something for it to only energize when it has to change states. When it opens at 55, for it stay open until it goes down to 45 for example. What would I use for that? Thanks again.
Post your program. Zip it first
You're right. The level is controlled by a simple solenoid valve. Temp is with pneumatic valves through a 4-20ma I/P transducer. I'll post the updated zip later, it's on my laptop that I don't have here with me right now.
I'm getting towards the end now. It pretty much all works as it should, though the the PID could still use some tuning.
One last thing I didn't mention. Temperature on the unit can also be controlled by 2 solenoid valves rather than the pneumatic valves. I don't see a reason why you'd want to do this, but that's the way it is setup. One valve will shut off hot water when energized and the other for will shut off cold. If i wanted to make a simple on-off control for this, is there any reason why the logic can't be pretty much the same as for the level control? Use 2 GEQ's for the limits, and when one valve is closed the other is open and vise versa? Is there a better way? I plan on trying it tomorrow if I can, but have been very busy these last 2 weeks.
Hello all, I have an issue with a PID block in RsLogix 5000. The parameters are P: 3.25 I: 0.11 D: 0.01 The Set Point is 71 psi This loop...
63
14,837
So were commissioning all the PID loops I had programmed to work with the new wonderware HMI system that was installed. Got all but 1 tuned pretty...
2,356
Allen Bradley PLC 5 What operations wants to do is as the Oil Flow rate (0-3000 m3/d) increases more chemical is injected into the flow line...
2,495
Hi All, I have been asked to modify our contact tank pumping station controls. Currently pump speeds are manually entered (as %) by operators...
2,235
Good Day, I have been programming for a while and a complete newbie in using a PID Control block. Now i am studying 📚 it using PC...
4,583
