Help on PID control
This will be a problem for Delta too since no one really wants to get into the control theory I have done.
Are the next applicable control theory algorithms significantly profitable? Kluged systems still fill chief sleazeball officer's pockets. Profit or requirement; that valve I pointed out only has that much info because an 3rd party institution requirement. Aerospace and defense also force sales to produce data and that data carries over to non critical systems.
I was expecting reference articles.
You're referenced Alfa-Beta-Gamma article was very enlightening.
https://www.kalmanfilter.net/alphabeta.html
Nice find. The alpha-beta filter is easy enough to implement on most PLCs. It should be used for estimating speed like in the article.
I have derived the digital form of the alpha-beta-gamma filter from scratch and determined how to set the filter values so there is little if any phase lag.
BTW, the RMC200 supports alpha-beta-gamma and alpha-beta-gamma-delta filters so it can estimate accurate position, velocity, acceleration and jerk from feed chains so the estimated values can be used to generate very accurate feed forwards for slave axes.
Most people just gear positions but that results in the slave axes lagging behind the master.
So were commissioning all the PID loops I had programmed to work with the new wonderware HMI system that was installed. Got all but 1 tuned pretty...
2,356
Allen Bradley PLC 5 What operations wants to do is as the Oil Flow rate (0-3000 m3/d) increases more chemical is injected into the flow line...
2,493
Hi All, I have been asked to modify our contact tank pumping station controls. Currently pump speeds are manually entered (as %) by operators...
2,231
Good Day, I have been programming for a while and a complete newbie in using a PID Control block. Now i am studying 📚 it using PC...
4,582
I'm working on a PID ladder logic program to control a small process trainer as a college project. 2 valves in a split range setup control hot...
20
5,162
