help with Rslogix 5000 and powerflex 40
stu
Aug 2005
England
786
Hi guys
I have a question about rslogix 5000 , I have a machine with 5 powerflex 40 with Ethernet , as the machine has already been programmed does the powerflex parameters stay in the plc, eg if I changed the powerflex do I have to load the data to the drive or does the plc download it ??
It depends of the integration method, however, probably the Component Class PF40 application file (if previously saved!)needs to be downloaded separately via dedicated software such as DriveExecutive.
There are instances where the developer has chosen to use CPU ladder logic explicit/implicit messaging/RPIing in order to "write" to the drive's onboard processor. This instances, however, target only a small portion of the drive's configuration data; the MSG/RPI-ing is restricted to only functional process parameters and not to the VFD's attached motors ratings parameters or independent drive functionality settings
I am completely stuck on building a ladder program that requires a start button to be pressed 3 times to turn on motor 1. Then motor 2 starts...
20
634
Hello Everyone, I have tried to access the help function from my RSLogix 5000 but everytime I select a function block on the PLC rung and press...
1,292
I’m working with indirect addressing and trying to make an HMI where each Rectangle Object has a tag of “A[0-127]” with a correlating Push Button...
4,232
I have been tasked to upgrade some SquareD PLCs at our plant. I have done several of these upgrades without any issues. However, I have now met my...
2,456
Hi There, When i did FRD instruction in SLC 500 its working, when i try to simulate in RSLogix 5000 same way as i did in SLC 500 which is not...
2,749
