Help with simple practical SCADA demo
aap
Dec 2013
Blah
Hi folks,
Disclaimer: I'm a PLC newbie! :D
I need to create a small and cheap PLC/SCADA demo, where the underlying idea is to experience with security of SCADA.
My idea would be to have
- a proximity sensor: probably an inductive prox sensor as they seem cheaper. So it'll detect if I put some metal close to it.
- a PLC, to be programmed
- a on/off switch: to power on/off [reset] the demo
- two light bulbs or LEDs one green, one red.
Whenever I put some metal close to the sensor, the green bulb lights.
After 10 times, the red one lights.
Or something like that.
Now, in practice:
- there are inductive proximity sensors around $17 at AutomationDirect.
- Koyo DirectLogic DL05 also seems relatively cheap at AutomationDirect, or I could perhaps find a second hand one.
- to program the PLC, I need a cable D2-DSCL
Q1. How do I connect the proximity sensor to the PLC? Do I need a specific cable? :confused:
Q2. How do I connect the PLC to the two red/green LEDs? :confused:
Q3. My scenario lacks usage of ModBus or DNP3... which would be great testing. Any ideas to evolve it?
-- Aap
Thanks, I had read the manuals, but I guess I don't understand them fully.
In my case, the sensor is NPN so it must be connected to a current sourcing input.
Now in chap2 of the manual, they explain the wiring, but I miss the basics :(
"wiring" = I just put a wire between the input and I solder ???? or else ?
"supply" = is that a shortcut for power supply ? or else ?
Thanks, actually, my question was more about wiring and I found the answer here:
http://plchowto.com/wiring-plcs/
Though I still don't know what kind of wire I should be buying. Sorry for the silly question but does Arduino-like breadboard wire work? or do I need something else?
Also, where can I get a suitable 12-24 VDC power supply?
Thanks!
This sounds more like a PLC example, not a SCADA example.
Most panels are built with 14awg stranded blue wire, but the actual gauge you use depends on the nearest branch circuit rated interupt device (fuse / breaker).
AutomationD would probably be the best bet for a cheap power supply.
Yes, you're right. But if I want to supervise anything, I've got to start with this, haven't I?
Ok, I found for instance CLICK C0-00AC, which is a 24VDC power supply at $ 29.
My understanding is that you plug that into your own power source.
I found hookup wire at $ 33 at Automation Direct, but I find that a bit expensive (half the price of the PLC !), and I certainly don't need that length of wire... Any idea where I would get cheaper wires (if possible in Europe) ?
Thanks !
Hello, We are beginning to use the View Designer software for the newer Panelview 5500 and 5300 HMIs. I one we are starting with is the 5300 10"...
1,204
I need help answering a problem regarding the design a ladder diagram for a security light control. The question states when a sensor is...
2,060
Question 1: I am still new to this - I also might be asking for too much. - but i need help using Ladder Logic to run (rod style actuator motor)...
1,688
Could someone help me write a simple program for my Click PLC (I am only new to PLC's) I have 2 switches and two lights that will time 2 separate...
52
10,382
Hello. After doing a couple quick searches I couldn't find anything concrete on what I should use for a simple ladder drawing program. Since all...
1,796
