Help with Zelio FBD
kallileo
Jun 2008
Thessaloniki, Macedonia, Hellas
353
I'm trying to create an automatic washing process which consists of 3 washing cycles.
The first and third cycles consist of 3 phases:
Water Intake (valve) Q1
Washing (pump) Q2
Drain (drainage valve) Q3
The second is the main washing cycle consists of 4 phases:
Cleaning Agent (valve) Q4
Washing (pump) Q2
It was fairly easy to do in Ladder by just using a timer (10 in total) for each phase but I'm not familiar with FBD.
What approach should I use? o_O
Maybe using the cam block would help...
Post your Zelio ladder program, and maybe someone will convert it to a FBD. There was a Washing Machine program in RSLogix posted on this site several years ago, and it is probably still here.
It sounds as if a Cam Block would be a good substitute for the timed drum switch in the typical washing machine - at least in the old machines. Now they are going with programmed electronics.
Just a bit stuck here ? I enclose a program I did a while back (with assistance from here :thumb:) of a two pump control where Pump 1 starts...
4,716
Hi, I'm new to the site and was looking for some help with Zelio ladder logic. I'm an electrical apprentice and am currently in training and my...
1,283
I need help. I have 6 zelios that need to talk with each other. I'm setting up an evacuation system at my mill. I have 2 pull station at each...
4,497
I am using a Zelio SR2A101FU controller and Zelio Soft 2 programming software that is version 4.3. I am connected via USB to my laptop which is...
2,056
i recently learn PLC AB slc 500 and start using zelio smart relay for my own small compactor business instead of timers and relay i used and made...
6,334
