Newbie needs help with Zelio
dkatwdsd
Feb 2011
Prospect, KY
I am using a Zelio SR2A101FU controller and Zelio Soft 2 programming software that is version 4.3. I am connected via USB to my laptop which is running Windows XP. I have written a simple program that turns a light bulb on. When I run the program on my laptop in Simulation Mode, it works as I expect and the gate closes and stays closed. When I download the program to the controller and try to run it in Monitoring Mode from my laptop, it does not work the same. The gate closes but immediately opens again. It does not stay closed as it does in the Simulation Mode. I have tested the controller using a piece of wire and it also turns the light on and it stays on. So, why can I not run the program in the controller from the laptop? Hopefully I have explained this well enough. I am a newbie with this. Thanks in advance for your help.
I've used FTView ME for as long as I can remember but am now developing an application with SE. I've imported an ME project that will serve as...
1,482
Have a 1500 thats used on a Italian Roller Coaster. Uses a couple of AIC's and a 500 Plc Also a Panelview 550 Everytime we go thru the start...
1,530
Hi all, Please can someone help me? I am new to programing and stuck on a task. I am working on RS LOGIX 5000 with a compact logix 5370 controller...
3,073
How do you reset the value you have into n7:88? Would a oneshot work? Thank you in advance and sorry for the easy question. I'm new and learning.
1,638
hi! to all, can someone gimme a download link of siemens s7 ver.4 sp1? We have lost our dvd installer and we don't know now what to do. can...
1,923
