newbie needs help
jusalgt2
May 2012
iligan
hi! to all,
can someone gimme a download link of siemens s7 ver.4 sp1? We have lost our dvd installer and we don't know now what to do.
can you guys advice us what to do? we are from a University and we have purchase 10 PLC's last 3 years ago. :)
your help will be appreciated.
what I was thinking of that.. :) anyways thanks mate.. we legitimately purchased those PLC's of course.
thanks for your advice.
It doesn't matter where your PLC's came from, the software is a separate purchase.
That's not the issue - they purchased both the software and the PLCs, however appear to have lost the original install disks. Whether or not Siemens will help them out without a new software purchase is another story!
ALL the install disks are available online for free. Siemens hosts its own disks, not sure about other manufacturers. (or they did a couple months ago when I needed them)
You can use your original license keys with any install disk.
If you don't have a license, then you need to get one for each install.
The IT dept loves to clone hard drives and setup new laptops with a ghosted image and then Siemens and AB notice they have 15 installs and only 10 licenses.
So try to keep your installs sorted or the auditors will disable some of your software.
Thanks guys for the prompt reply. I try to download from the siemens website. the higher version which has new interface compare from the old one. anyways, it just need a bit of exploration I know.
thanks guys! keep safe. :)
I've used FTView ME for as long as I can remember but am now developing an application with SE. I've imported an ME project that will serve as...
1,482
Have a 1500 thats used on a Italian Roller Coaster. Uses a couple of AIC's and a 500 Plc Also a Panelview 550 Everytime we go thru the start...
1,530
Hi all, Please can someone help me? I am new to programing and stuck on a task. I am working on RS LOGIX 5000 with a compact logix 5370 controller...
3,073
How do you reset the value you have into n7:88? Would a oneshot work? Thank you in advance and sorry for the easy question. I'm new and learning.
1,638
I am using a Zelio SR2A101FU controller and Zelio Soft 2 programming software that is version 4.3. I am connected via USB to my laptop which is...
2,054
