Newbie needs Help (RS Logix 5000)
nenz
Feb 2014
Manchester
Hi all,
Please can someone help me? I am new to programing and stuck on a task.
I am working on RS LOGIX 5000 with a compact logix 5370 controller type. I am trying to use compact flash to save and load “variable values” to a common PLC program. These values shall be changed when needed using the compact flash. It looks like this is possible from my research using the compact flash but the controller I am using only has an SD card.
So my first question, can it be done using the SD card?
I have been looking through the “CompactFlash File System on Logix5000 Controllers” document and have sample files to help me implement this.
•CF_Read_Write_V3_2.ACD
•CF_Read_Write_V3_2_Example.ACD
Am I looking through the right documents and on the right tracks? Please can someone explain or direct me towards the right tracks, i.e. relevant documents or videos to help me achieve this?
Thanks for all your help in advance J
Kind Regards
Nenz the newbie
Welcome to the Forum !
This is an advanced feature in CompactLogix and not really appropriate for a novice, but you're on the right track.
The CompactFlash and Secure Digital filesystems are identical from the controller's perspective. As far as I know, anything written to work with CompactFlash will also work with SD cards.
There is also a Programming Manual that supplements those examples, available from the RA Literature Library.
Logix 5000 Controllers Nonvolatile Memory Programming Manual, Publication 1756-PM017.
Direct link to PDF:
http://literature.rockwellautomation.com/idc/groups/literature/documents/pm/1756-pm017_-en-p.pdf
Thanks Ken Roach
do you think you can shed some light on how this is achieved? it seems to me that all the work has been done in the example files. i am under the impression that i can save the example files on the SD card and only need to edit specific bits in a tag that has been created by the example file.
do you know of any videos that can help with this?
thanks again
I've used FTView ME for as long as I can remember but am now developing an application with SE. I've imported an ME project that will serve as...
1,483
Have a 1500 thats used on a Italian Roller Coaster. Uses a couple of AIC's and a 500 Plc Also a Panelview 550 Everytime we go thru the start...
1,532
How do you reset the value you have into n7:88? Would a oneshot work? Thank you in advance and sorry for the easy question. I'm new and learning.
1,649
hi! to all, can someone gimme a download link of siemens s7 ver.4 sp1? We have lost our dvd installer and we don't know now what to do. can...
1,924
I am using a Zelio SR2A101FU controller and Zelio Soft 2 programming software that is version 4.3. I am connected via USB to my laptop which is...
2,055
