OkiePC
I had a chat with the other safety person, one on one, and it went fine. He understands the situation and is working on fixing it...
Uh, nope. Sounds nice, seems okay, but nope...Locking out estops would be okay to keep someone from being able to turn on a machine for a non-safety related reason.
While it is true that Sparkie missed the boat on the E-stop question, he did hit upon one other aspect of LOTO that I personally feel is critical:
Each piece of equipment should have posted in a conspicous place a procedure that identifies each potential energy source, and the PROPER procedure for locking it out.
With this document in place around the equipment, and documentation of training of the plant floor workers, the company is protecting its' assets from lawsuits around negligence.
If I were in your position, I would recommend to your safety department that they develop a "crew of volunteers" to go around and develop this documentation for the equipment during scheduled downtime. In this manner, you can volunteer for the "crew" and help those associated to understand the importance of the assigned task.
And, I think I would make this recommendation to the safety leader, as well as the plant manager IN WRITING. They will almost always respond positively if you put the request in a form such that they can't claim ignorance later. Be sure to include the protection from liability in the note, and don't point fingers (not that I think you would after reading your former posts) or blasphemy anyone.
Best of luck, and don't back down, I don't think that you'd forgive yourself if you did and someone was injured as a result!!
We have a few different styles of local disconnect switches. We also have banks of disconnects with a lockout cable that passes through all the handles and you only need to use one lock for the bank. Apparently it is possible to throw a disconnect handle back up with the cable through since the cable can bend and move on some of them. Some switches are better than others and can't be bypassed in this way.
In my mind, turning on a disconnect with a cable through it is no less illegal than cutting a lock in order to turn it on. Turning on a locked out disconnect is malicious intent no matter the situation.
My point is, where do we draw the line? Individual locks on each switch? A human guard to stand by an ensure nobody screws with the lockout? If someone wants to kill you, they'll find a way to kill you.
In Japan they just stared at me like I was speaking English when I asked where I could lock out the supply circuit before working on a 100A main lug set; their breakers and disconnects simply do not have lockout hardware.
