Hex to Decimal studio 5000
RioPLC
Nov 2019
new jersey
19
I am trying to convert hex values to decimal.
I am reading in values from 232ASC module.
They come in on ___:4:I: Data[0] & ___:4:I: Data[1]
Data[0] reads 16#04 and Data[1] reads 16#a4
I would like to convert these numbers to decimal in ladder.
Is there a way to do this in studio 5000?
Don't use a MOV, use a COP. MOV attempts data conversion, but COP preserves the bit pattern. You might need TConnolly's solution in the thread linked above if you receive a value with bit 15 set to "1".
šŸ™ƒ
I am using a Micro 850E PLC (the new one with implicit messaging capability) to drive a Kinetix 5100 servo drive. The error code number on the...
1,718
Hey All, i have been fortunate enough to play around with an Applied Motion Products Servo Drive SV200 with 100 watt/ 24vdc congif. I managed...
1,893
Hi I'm using Mitsubishi FX5U with a GOT HMI. I need to enter values on HMI in decimal format then convert to HEX for use on a Modbus RTU link...
3,093
Hi all, great forum I'm learning all the time on here. I'm having a problem with a g308 in that I can read the data in hex, but when I try to...
2,228
i'm newbie in PLC, would u like to help me, plese.. i'm using an instruction MOV, for moving Hexadecimal data #0020 which is &32 in decimal,to...
1,827
