High Power Panel Mount Indicator Light?
jordanat2012
Aug 2018
Illinois
22
Hi all,
This one isn't strictly related to PLCs, but more a component the PLC is driving. I'm working on a museum diorama that is controlled by an Allen Bradley Micro850 PLC with 24vdc sourcing outputs. I'm trying to find a panel mount indicator that operates at 24vdc and is as bright as possible so that I can illuminate certain areas of the diorama.
Right now I've got McMaster part number 2779K205 being driven directly from the sourcing output, but it's not even close to bright enough. If I'm looking at the user manual for the controller correctly, I can pass up to 0.3A directly through the sourcing output.
Does anyone know of a panel mount indicator, preferably white, that would provide a bright light?
Thanks!
Thanks for the idea Aabeck - I had looked at Digikey and Mouser, but hadn't thought of IDEC yet. I'll check them out.
I thought of relays too dogleg43. I've got that in my back pocket still, but was trying to avoid it as best I could. I have 25 small lights I need to control, and adding 25 relays was something I was trying to avoid.
I saw at a trade show some "Daylight Bright" indicator lights. They were very bright.
I thought it was from Idec, but a search showed these from Banner. And these from Digikey.
How bright is bright? What was the lumen output of the ones you tried and felt were insufficient? Can you try to find a light of any voltage that meets your lumen needs, then find a 24VDC one with that output AND within your power limitation? Research is your friend here.
Hi, Is it possible to switch on a 30 Kw motor using a plc output with only 2A contact capacity? How can I make this possible?
2,972
We have a few Versaview 1500p on the field. They seem to fail more than expected so we decided to take a look to the high voltage power supply...
2,928
Passively, an SCR behaves as virtually an open circuit to voltage pressure (attempted current flow) in either direction. When a small current...
4,075
Here's some interesting pic's and video clip of a High Voltage Power Line 500 kV Circuit Switcher being tested...
5,963
Do i have to use interrupt subroutine, or immediate read high speed input, for Unitronics Samba plc or reading only the correponding register in...
124
