High Speed Pulse Train Echo
Jack Brown
Nov 2011
Dundas
I'm using an Allen Bradley ML 1400 PLC. I want to take a pulse train into the PLC
which can vary from 0-3000hz and echo it to an output from the PLC. Basically pass the pulse train through the PLC unchanged 1 pulse in, 1 pulse out. The PLC has high speed inputs capable of 100k hz operation it also has high speed FET outputs. The high speed counter runs independent of the regular scan time of the PLC. Is it possible to use the PTOX command to do this echoing? Has anyone tried something like this?
interesting the hsc input acc would have eximaned in the ladder than wrote to the output I think this would cause an ofset in the timing by at least 1 scan?
Unless you need to modify the pulse train I wouldn't go through the PLC, just split the incoming signal, one channel to your PLC and the second to the other device. You can do this with a purpose made/designed splitter or use opto-isolators.
it is impossible as the outputs must run on the ladder, the counter is independent of anything, just counts and when asked for it gives the number.
when you want a switch just use a standard relays on an output and use the input parallel to this relais.
You could use a repeater or optocoupler.
Hello, To make it short, the current system setup is a compact logic with a high speed counter 1769-HSC input module reading pulses from a flow...
2,001
Hi, I am trying to count rate of pulses in given time period (say every 5msec for 2 minutes). The pulses arriving might have max frequency of...
2,794
Hey, In ladder logic how would I convert a high speed counter input into rpm using a control logix processor?
2,347
Hi, I am growing in my Omron knowledge, but this one has me scratching my head. We have a customer with an Omron spec project that wants to...
2,968
Hai everybody, I have a small issue of adding delay in the pulse count of the high speed counter input of the micrologix 1100.The pulse comming...
4,418
