HMI FTView ME
Abdul03
Jun 2012
England
77
Dear All,
I have a small question about adding a confirmation popup when a button is pressed in FTView ME, asking a reconfirmation from the operator (yes or No). when the operator presses YES, it should shut down the machine and switch to the previous display (close the popup in other words).
I hope somebody could able to help me out.
Thank you and highly appreciated.
Regards,
Abdul
Hi, don't believe (??) is a canned function, but you could have the on / off control call another confirmation popup... If you have a pile of them, can be common popup with parameters...
It's certainly possible to do what you describe, and there are, I'm sure, several ways to achieve it.
I normally create one screen used as the pop-up and use parameter files for each instance of the 'action' button. The 'No' or 'Cancel' button is just a regular screen navigation button. To get the action button to also close the pop-up, I create a Global connection tag to close all on top screens and use the PLC action to also set the global tag...
Hope this helps
Rob
I have running FactoryTalk View SE v7.0 on Windows XP normally for a long time Now I have the following error message : Database conversion or...
2,127
I am looking for some suggestions on the best course of action for migrating my customers FTView SE Distributed project from v9 to v12. The...
1,886
Working on a customer's FTView SE Distributed (v11) environment, and I am using one of the workstations for development. I have been getting a...
1,443
Hello all! My customer asked for an HMI programmed with "Safe View" approach to avoid too many windows to be opened at the same time. He wants...
1,924
