themostlymen
i check this log and i have information that during 'skipped time' the HMI screen isnt updating.
3332399 2014-01-10 오후 7:02:55 164 176 Info HTSPT HTSPT.DLL - 10.5
3332400 2014-01-10 오후 7:02:56 2156 2160 Info hd InTouch Historical Data Server - 10.5
3332401 2014-01-10 오후 7:02:56 164 176 Info VIEW Wonderware I/O Server Toolkit for Windows NT - Version 7,2,1,11
3332402 2014-01-10 오후 7:02:56 164 176 Info UNKNOWN Suitelink: OpenServer - Registered Server Name: (VIEW )
3332403 2014-01-10 오후 7:02:56 164 176 Info view ddeclikt: Toolkit Build ID Aug 23 2011 00:12:55
3332404 2014-01-10 오후 7:02:56 164 176 Info VIEW ddeclikt: Registry Key Read - SOFTWARE\Wonderware\ddeclikt\Default
3332405 2014-01-10 오후 7:02:56 164 176 Info VIEW ddeclikt: DisableAutoRegistryRead = 1
3332406 2014-01-10 오후 7:02:56 164 176 Info VIEW Setting current View window HWND = 65900
3332407 2014-01-10 오후 7:02:56 164 176 Info VIEW Script '?d:MD_Alarm00 = ?i:M' can't run with placeholders
3332408 2014-01-10 오후 7:02:56 164 176 Info WZALMOBJ WNAL - using "AlarmLst.dll"
3332409 2014-01-10 오후 7:02:56 164 176 Info WZALMOBJ WNAL - Loaded AlarmLst DLL "AlarmLst.dll" version "10.5"
3332410 2014-01-10 오후 7:02:56 640 644 Info AlarmMgr Connected to Provider '\intouch'
3332411 2014-01-10 오후 7:02:56 164 176 Info INTSPT Node "localhost" connected
3332412 2014-01-12 오전 4:14:30 164 176 Info VIEW Loading Script DLL: WINMM.DLL
3332413 2014-01-13 오전 7:57:02 1248 1288 Info aaLogger Logger Shutting down.<<< (this one is manually reboot the pc)
3332414 2014-01-13 오전 7:57:42 1288 1296 Info aaLogger Logger Started.
3332415 2014-01-13 오전 7:57:42 1288 1296 Info aaLogger Logger Started.
3332416 2014-01-13 오전 7:57:45 276 560 Info aaBootstrap The Bootstrap service is starting...
3332417 2014-01-13 오전 7:57:45 572 584 Info aaGR aaGR Started
3332418 2014-01-13 오전 7:57:45 572 584 Info aaGR Published PackageServerNet on port 8090 (0x1f9a)
3332419 2014-01-13 오전 7:57:46 596 2140 Info PlugInDDESL Timers: prot=50. validData=60000. Request=1000.
3332420 2014-01-13 오전 7:57:46 596 2200 Info UNKNOWN Wonderware SSC - Version 7,0,100,1 (3 : 1.1) (2 : 4.1) (3 : 5.0.97)
3332421 2014-01-13 오전 7:57:46 596 2200 DACmnProtWarn DASSIDirect Valid license is available
3332422 2014-01-13 오전 7:57:47 596 2140 Info DASSIDirect Wonderware I/O Server Toolkit for Windows NT - Version 7,2,1,8
3332423 2014-01-13 오전 7:57:47 596 2140 Info UNKNOWN Suitelink: OpenServer - Registered Server Name: (DASSIDirect )
3332424 2014-01-13 오전 7:57:47 572 1828 Warning aaGR Failed to acquire any type of license feature 'GR_Runtime' of version 3.5
3332425 2014-01-13 오전 7:57:47 572 1828 Warning aaGR Failed to acquire any type of license feature 'IO_Count' of version 3.5
3332426 2014-01-13 오전 7:57:47 572 1828 Warning aaGR Failed to acquire any type of license feature 'Platform_Count' of version 3.5
3332427 2014-01-13 오전 7:57:50 276 560 Info aaBootstrap The Bootstrap service is running.
3332428 2014-01-13 오전 7:57:50 276 560 Info aaBootstrap The Bootstrap service is entering the message pump...
3332429 2014-01-13 오전 7:57:50 276 2480 Info aaBootstrap Starting the Bootstrap components...
3332430 2014-01-13 오전 7:57:53 276 2692 Info aaBootstrap The Bootstrap Monitor started.
3332431 2014-01-13 오전 7:57:54 276 2700 Info aaBootstrap The Bootstrap Manager started.
3332432 2014-01-13 오전 7:57:55 276 2480 Info aaBootstrap The Bootstrap of version <3102.21.0.0> built on Sep 26 2011 (13:25:27)
3332433 2014-01-13 오전 7:58:08 156 168 Info SQLMNGR 10.5
3332434 2014-01-13 오전 7:58:08 156 168 Info WC Wonderware Systems,Inc. InTouch Windows Controls 10.5
3332435 2014-01-13 오전 7:58:08 156 168 Info INTSPT 10.5
3332436 2014-01-13 오전 7:58:08 156 168 Info VIEW 10.5
3332437 2014-01-13 오전 7:58:09 156 168 Info INTSPT Alarm Manager command line args < >
3332438 2014-01-13 오전 7:58:09 156 168 Info INTSPT ... Starting Distributed Alarm Manager ...
3332439 2014-01-13 오전 7:58:09 156 168 Info AlarmLst AlarmLst -
3332440 2014-01-13 오전 7:58:09 156 168 Info AlarmBuf AlarmBuf - 10.5 Using Win32Heap
3332441 2014-01-13 오전 7:58:09 156 168 Info INTSPT WNAP - using "AlarmBuf.dll"
3332442 2014-01-13 오전 7:58:09 156 168 Info INTSPT WNAP - Loaded AlarmBuf DLL "AlarmBuf.dll" version "10.5"
3332443 2014-01-13 오전 7:58:09 3892 3896 Info alarmmgr Distributed Alarm Manager - 10.5
3332444 2014-01-13 오전 7:58:09 3892 3896 Info alarmmgr Copyright (c) 2011 Invensys Systems, Inc. All rights reserved.
3332445 2014-01-13 오전 7:58:09 3892 3896 Info AlarmLst AlarmLst - 10.5
3332446 2014-01-13 오전 7:58:09 3892 3896 Info AlarmBuf AlarmBuf - 10.5 Using Win32Heap
Can u give suggestion what should i do with the HMI?
