HMI, PLC & VFD's communication
talrejasub
May 2009
mumbai
I have one 15Hp Delta VFD c-2000 series, two 3 Hp Delta E series VFD's , DElta DOP-B HMI & Delta DVP 14ss2 PLC. I want to control the weight of the our product through weighing machine connected to plc with compatible Load cell module.With this I have to run all the three motors in closed loop to automatically vary the speed of the three motors for controlling the weight of the product. The three motors will run with different ratios. The ratios of the three motors may change with different items, we are manufacturing. I want to know what things will I be needed apart from the Load cell module. I mean if I need analog output module. currently I am varying frequency manually by potentiometer. Also I want to know about modbus communication & which Load cell module , I will be needed.
Can anyone help.
Regards,
Subhash B. Talreja
Contact No. 9890191949
Delta do a load cell module so i would use that first. Then use modbus to link to each drive.
Much easier and less wiring and easier to programme.
Cheers,
Brett
Hi gents I have weintek HMI (MT6070IH) and s7-200 plc cpu 224 and vfd which supports rs485 modbus rtu communication. The plc has 2 ports, one...
797
Easy, basic question... this is my first time linking 3 ABB vfds to an Allen-Bradley PLC using ethernet IP, and the odva Drive assemblies 123 and...
2,495
Hi all , Is it possible to control a VFD using HMI without a PLC. And the HMI is Emerson CTVUE-303L/M/S 3”, 128 x 64, LCD Display Ethernet...
25
11,833
Good Day to all of you, this is my first post, i will try to explain as best as possible, english is not my natural language. I am performing an...
48
Hi, Wy we log data in PLC using DLG instruction, when we have option to log data in HMI
81
