nwboson
Looking for suggestion of HMI that will support redundant logging.
What I mean by redundant logging: I'd like the HMI to log data from the PLC's (two models - GE 9030 and AB ML 1100/1400, both Ethernet) into a removable CF or SD card. If an operator then plugs in a USB flash card, I'd like to prompt the operator to select the date range of previously logged data, then squirt a csv file out onto their USB flash card. So its redundant in the respect that I want a removable flash card in the HMI plus an operator-installed USB flash for the take-away logged data.
I would also like the HMI to have an RS-232 port that could print logged data directly to a tractor feed or thermal printer in real time.
Size doesn't matter - the smaller the HMI the better. I just need the HMI so the operator can select the date range to be written to the USB flash.
I've been a long-time user of the Red Lion Operator Interfaces but they don't have the USB host port. Otherwise the RL would be perfect.
I looked at the Maple 5070TH and it looks like it may do the trick. No experience. I'm real concerned about their scripting language especially since they just call it 'macros'. I love the Red Lion scripting since it seems like I can always get it to do anything I can dream up and I sure would be disappointed to take a step backwards.
I figure I'll need fairly robust scripting to select the date range and build up the csv data list...
