HMI Temperature selection
gusterminator
Feb 2009
Thunder Bay
85
Thanks for all the help earlier....I have my Fixed SLC 500 1747L20 working with RSview properly scalled and comunicating with my RTD transmitter for 0 to 100 degrees C. I would like to know if someone could point me in the right direction to have a ajustable temperature range on my HMI screen that I could compare with my current temperature that I have displayed on my current HMI screen.
Adjustable temp range
I am not sure what exactly you want..
If you want adjustable temperature range that you can vary as per requirement, then you need to place numaric input entlry in HMI that will allow you to modify temp and then you can insert a rung in plc having subtract instruction that will give you a difference reading and you can move it to 1 temporary register that will allow you to use that diff value in your proces..
this is what you want or else??
that is exactly what I was looking for...I'll do some reading on using numaric input entry in HMI if I can find it....and I was also wondering about a temporary register holding a value for me and you verified that.
I'm just learning....I like reading, I just don't know the right search terms sometimes when I'm searching the forums and Internet.
Thanks for the help.
Anybody know of an HMI with a temperature rating above 60 degrees C? Ideally, it would also be rated for Class 1 Div 2.
8,956
Hi, We currently use PanelView plus 6 HMI. Is there anything from Allen Bradley in the same price range but that has a low temperature rating? I...
2,991
Here is our latest post that we would like to share. Modbus RTU will be the serial (RS485) method in which we will communicate between the...
1,465
i HAVE COME ACROSS THE OMRON HMI NP SERIES NPMQ0001.HOW I CAN CONNECT A THERMAL PRINTER TO NP SERIES HMI USING RS232 AND TEMP.CONTROLLER TO NP...
4,147
123
