Honeywell DCS PMIO Analog Output Fault
engr83
Jun 2013
Karachi
We are facing problem related to honeywell DCS, Process Manager IO Analog Output Module (MC-PHAO01). While running it goes to NO RESPONSE state resulting plant to trip. After reinserting the module, it works fine. We also checked by replacing the module but even on new module this problem occur. the frequency of this erros is 3 times per year.
There is no cause or corrective action written in knowledge builder. Need to pin point the problem.
Need advise
Regards & Thanks
hello everyone we work on a water station using plc schneider M340 and we should make a communication with a dcs honeywell , this dcs should read...
1,314
good day friends, With regards to the Honeywell Experion analog input/output cards, my understanding is that we can de-activate every single...
1,223
Hi All I am currently working on a project using Honeywell Experion and am trying to map some Profibus IO that is being brought back over an SST...
1,706
Hi Gurus , I need sources, books, videos or online training on Honeywell PLC and DCS ? I am living in area that DCS related work is dominated by...
2,444
Hy, we have a Honeywell DCS TotalPlant Alcont, to which we added a new digital output module BOU. On this module there is a Disconnect or D switch...
2,328
