Honeywell DCS Prfoibus IO Mapping
toddster900
Oct 2011
England
35
Hi All
I am currently working on a project using Honeywell Experion and am trying to map some Profibus IO that is being brought back over an SST card. I have successfully added the Profibus Interface block and a Profibus Device block for each Profibus module. Each Profibus module equates to 20 bytes of data containing several control or status words from a CPU in an MCC.
However at this point I think I have gone a bit wrong. I am trying to map two bits from a status word and one bit from a control word. To do this I have used a Profibus Input/Output Channel block for each bit.
Is this incorrect? I now suspect I may just need one Profibus Input Channel block for the status word and one for the control word. Is this the case and if so how do I then access the bits I require?
Thanks in advance!
hello everyone we work on a water station using plc schneider M340 and we should make a communication with a dcs honeywell , this dcs should read...
1,314
good day friends, With regards to the Honeywell Experion analog input/output cards, my understanding is that we can de-activate every single...
1,223
Hi Gurus , I need sources, books, videos or online training on Honeywell PLC and DCS ? I am living in area that DCS related work is dominated by...
2,444
Hy, we have a Honeywell DCS TotalPlant Alcont, to which we added a new digital output module BOU. On this module there is a Disconnect or D switch...
2,328
We are facing problem related to honeywell DCS, Process Manager IO Analog Output Module (MC-PHAO01). While running it goes to NO RESPONSE state...
2,379
