I use a lot of WCON blocks to reconfigure other blocks on the fly, especially the FGEN block (for loading thermocouple corrections).
Yes I have a big gripe going on with Honeywell on what you can and can't write to with Modbus.
The other big gripe is the SPP block, you cannot write to it once the SPP is started. All you can do is Run/Hold/End and Advance Segment. I would love to be able to edit the Ramp, Soak Temp, and Soak Time after the SPP program is operating (and No, it will not work when in Hold either, you have to reload a new SPP cycle to edit).
