How can be read macro
Osmanselim
Sep 2008
Turkiye
hi,
I have Fanuc 21 tb kontrol cnc Machine;
I want on ladder, read some Custom Macro Variable #3012 and write Rs232
is it possible?
Hello iam trying to read DB by using prosim lib inside excell macro. I added it in macro i can get cpu status but i couldn't use readDBValue...
2,121
I need to read the system tool counter on a fanuc control, using Macro B. I have tried variable #4120 but this only supplies the last programmed...
2,195
Hi, The hardware is: Click Plc model # CO-O1DD1-O HMI model # S3ML-R magnetic-inductive flow meter model # FMM100-1001. I will set the flow meter...
165
Is there a way to use the FAL instruction to do +=2 instead of +=1? I have an array that is organized with alternating "data" and "flag" values...
127
Hi everyone i have a customer, who wants to show an alarm on the machine, if the I/O forces are enabled and set, on at ControlLogix L81E with...
266
