How can I connect Beckhoff KL9050 to my pc?
There is nothing to program on KL7200, it is a bus coupler, not a PLC. It looks like some very rare thing, not even listed on Beckhoff web site. It provides remote I/O for devices running CTNet fieldbus manufactured by company Control Technics (I think this is an Emerson affiliate).
There may be a need to change the configuration of the bus coupler using a small connector on the bottom; for that you will need KS2000 software and cable form Beckhoff.
Start with just getting TwinCAT 3 on your computer. You can program through their trial licenses directly on your computer. No harware (Besides said computer) necessary.
TwinCAT 3 is available from their website in the downloads section.
Hello
I have a Beckhoff KL9050 module
https://www.dropbox.com/s/axo7n7g1gbtmmfj/bk7200.png?dl=0
I was wondering if anyone has experience working with Beckoff systems and knows how i can connect it to my pc and program it. I would appreciate any help.
As I know KL9050 is a module for extending K-BUS (a serial bus between KL cards of Beckhoff) and is usually used with KL9020 and I think you can not connect it directly to the PC.
I want to get into programming Beckhoff PLCs, what would be a good place to start?
There are some good Youtube videos for getting started--search for "beckhoff twincat" and you'll find them. Unfortunately Beckhoff doesn't provide a lot of "getting started" materials; I've found this to be frustrating as I'm also trying to learn Twincat. Their online help system (infosys.beckhoff.com) is comprehensive but meant to be more of a reference than a tutorial.
I'd also suggest this book:
http://www.amazon.com/IEC-61131-3-Programming-Requirements-Decision-Making/dp/3642120148/
I'm reading through it now and it's a good introduction to the IEC 61131-3 programming standard, which Twincat seems to follow pretty faithfully.
323
108
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
126
Here's what happened, Operator turned on the disconnect for an auger while it was still running to cut power. Auger DID in fact turn off, but the...
357
What has been your experience with year over year price increases on your Tech-connect service contracts? Is it up to the distributor? 30% seems...
296
