how can i connect industrial ethernet from home
tomkens
Dec 2003
manchester
21
hi folks
I work in a cement factory we have profibus network and industrial ethernet.all our plcs are siemens we also have a monitoring server and clint computers with a danish software
ECS
please help me how can I add appertunity of connecting to industrial ethernt from home through modem(progrmming plcs from home is enough for me)
please explain me which moudles or extra software I need
thank you
tomkens said:
hi folks
ECS
thank you
You do the same as if you where directly on the network in the shop BUT you need to know the shop's IP addresses and the ports used by your programming software. In the router you "forward" the comunication to these ports to the relevant IP addresses...
If you don't have Static IP you use something like "DNS2GO" and get them IP updated centraly.
Most people use PC-Aynwhere and hop on a real PC in the shop to remotly used them.
BE CAREFULL, doing remote things can be VERY dangerous.
Monitoring is harmless and usually for troubleshooting purposes.
Hi there, I have an RSView32 machine connected to a ControlLogix 5555 processor. Everything is well the system works. I am logging various data...
3,790
In our work area using 4 pieces PLC SLC5/03 that connects the DH 485 Industrial Network using 1747-AIC, how can we be monitoring the production...
2,896
315
106
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
121
