Create "Text list"
Text coresponding to a value you'll be supplying from the PLC. Bitwise or a number. Bitwise you'll need to make sure only 1 bit is set at any given time, else the default value will be used.
Insert "Symbolic IO field"
Set it to "Output"
Link it to the text list, link it to the tag.
All set.
