S7-1200/TIA v18: S7's equivalent of Mitsubishi PLF command...
Mas01
Oct 2020
Leicester, England
1,109
Does anyone know the S7 equivalent of the Mitsubishi Q-Series command PLF?
PLF is a one-cycle pulse on the falling edge of the input signal.
See picture for example.
In my case, on the falling edge of the "save button", I want to generate a pulse - when it's TRUE, I want to subtract one real value from another, but I only perform this subtraction when the pulse is TRUE.
I *think* the command I need is N_TRIG, but I'm not sure.
edited.
If you just want to have the oneshot in the same rung, then it is the -|N|- that you see in the instructions window. Instead of the -||- contact with the save button, change it to the -|N|-
If you want to create a oneshot impulse to use in another rung, it is the -(N)-
edited.
Awesome, cheers for this @JesperMP. It's working.
Follow-on question:
In monitor mode can you actually see it change or is it just too quick for the eye? I realise it's a oneshot.
Seems that the output "Calc Diff" is stuck on FALSE even when the input (per the description) changes from 1 to 0.
The pulse will be too short to see - if the subtraction has taken place then you know that it works.
See the attached pic ("workflow"). I want to create 2 workflows, depending on if the person who's just logged in is an OPERATOR or an ADMIN...
17
2,477
...and I agree. Context: TIA Portal/HMI = KTP1200 (12" screen) In the attached redacted image, the values in the white boxes are entered by the...
714
Hello PLC Friends, I'm starting my final year project with a given rig and I'm thinking about incorporating a remote access feature where I can...
369
Good, Code Totalizer: IF ( Hour = 23) and ( Minute = 59) and ( Second = 59) THEN totalizerDay_previous : = totalizerDay; totalizerDay= 0; End_IF...
1,567
Good day, everyone, We're trying to establish an S7 connection on ethernet between an S7-400 CPU and a new S7-1200 CPU (which is defined as slave...
2,627
