How can i simulate the speed signal
jcp
Feb 2010
Multan
369
Hi friends;
I am new witth that speed sensor. I want to simulate the speed signal plz guide me how can i simulate it? I have Fluke 741B and frequency counter as well.
The data of Speed probe is as under
60 pulses per revoulation
Supply Voltage +9.5 to + 15 V
Power consumption 40 mA
Tranducer Type MDg 14 Output signal +12 Volt depend on the supply voltage.
Range of working frequency 1 HZ to 30 Khz
The wiring diaggram is attached with it.
Output is suare wave.
I want to ask how and what value of Volt and HZ i give to simulate 5500 RPM.
Function generator have both options square wave and sine wave.
Which one i apply?
Regards
Use the square wave output on the function generator.
It looks to me like your sensor output will be roughly sensor supply voltage - 3V. So set your function generator voltage output based on the expected sensor supply voltage
The frequency setpoint for simulation would be:
5500 rev/min * 60 pulses/rev * 1 min/60 sec to give you pulses/second, or Hertz. Unit cancellation; what a beautiful thing.
Keith
Hi there, I'm doing some extensive testing and commissioning with a slew of new Emerson PACSystems RX3i PLCs. It would be convenient to...
108
Hello, I have a small application with a S7-1200 CPU 1212 and a KTP400 Basic HMI. When i am connected to the PLC with my PC i would like to...
547
Hello everyone, i would like to test and run os server in pcs7 v8.2 project without rear PLC.i used plcim on ES and nettoplcsim and adjust the...
1,336
Hi all, Im new to Allen Bradley software, so i was given a existing studio 5000 plc program. i already know how to use emulator and rslinx but as...
1,415
I want to run a simulation of a program uploaded from a rockwell PLC, but I can't configure the CPU on the emulate to match the actual CPU.
2,262
