I'm upgrading an HMI and would like see plc data being communicated through tags for testing purposes. I have set up a SLC 5/04 test station with a processor and a couple of modules, I would like to be able to download the existing program and go into data table and manually manipulate the numbers. My test station doesn't exactly match what is out on the line, so the processor faults because it does not see the other modules. Is there an easy way around this? On a PLC 5, all I need is just the processor, it won't fault if it doesn't see the racks and/or modules that are programmed. Thanks!
