How do you change the com port to defult
joeparrish
Nov 2007
owensboro ky
161
Ok I have a micro 1500 24bwa and the Plc Is set to a Pic driver I cant get online
So I was wondering If there is a way that I can set it to get on line with a rs232 dfi useing a 1761-cbl hooked up to my laptop
There are a couple of buttons to the left side of the plc \
one is for run remote and program
the other 2 are like screw ajustments they are 0 and 1
See PDF below:
If your laptop has a real serial port then you can use the 1747-PIC/AIC+ driver in RSLinx with your current cable and that will work. But to change port to its default see PDF.
no no real serial port I have a cardbus 2 port serial that I plug in the side works fine on everything but these 2 1500 that are set as pics in the program
I have tryed to go to rs linx every way I know and it will never see the plc.
Is it poss ble to just tell me the pdf just shows chapter at the top and nothing else
Its in the manual, Mickey posted Chapter 4 and its there. May want to upgrade your Adobe Reader, it is free.
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
178
Hoping someone can give me some guidance or confirmation of what I need to do. We have a FactoryTalk SE program that I need to change the IP...
102
Hey all, i have a panelview screen (image attached), with 4 items on it. Program 1, Program 2, ...3, ...4. The PLC i am using is a compactlogix...
189
Greetings I have a problem, my system is the following: wincc v8.0 (demo), logo8.3, abb m2m analyzer. I created some pages to display the...
75
We had one go down. we have a new one. Their emergency Number don't work. The Model is TLSA046AAH-330N01-007 A catalog says we need software TET...
172
