How do you remove the Schneider Driver Manager
Doug_Adam
Sep 2002
Perth
948
Hi All,
I loaded unity pro a few days ago, and now i have a problem with my pc freezing.
I don't know if this was causing the problem, but i wanted to remove it as a precaution. I managed to remove all exept the Driver manager (see pic).
Any idea of how to get it off?
Don't you hate that? I installed it inside a Virtual Box to avoid any problems Doug. Main one I had was the ruddy Modbus driver would not shut down. Would suggest you do the same.
Hi Bob, hindsight is a wonderful thing. I have been toying with virtualisation for a while. This event has motivated me.
As things turned out, my pc stopped freezing soon after I posted this. For no apparent reason. So Thanks for trying. and thanks seppoalanen.
If anyone does know how to do this, I would still like to know.
Don't know if this was the cause of my problem.
URuninstaller
Find "URuninstaller"
http://www.ursoftware.com/
This will uninstall anything, completely, local files, registry, everything.
I have been using the 2008 version for awhile and I love it, it even uninstalls things that are supposed to not allow uninstall, like pesky antivirus software.
Unity PRO is not something I would want to keep on my PC. After I did one project with it, I noticed issues too. I had it installed inside XPmode, so I just deleted the VHD.
With Win7 and 64 bit many people have come to realize that VMs are actually a great way to go, even if you don't really have to.
Virtual Box, VMware work, but I really like XPmode. Seamless hardware integration, no weird stuff, easy setup, AND a free copy of WinXP auto installs on first open in a few minutes
This might be a negative if you want to load a different OS. I don't know if you can load other OSs in "XPmode", it might work.
Hi, When the HMI (KTP1200 basic) powers up, the user has to enter their credentials to log in. In the screenshot, ADMIN has already logged in...
1,007
Hi I have removed at IO card from a 1734-AENTR Point IO, from a slot in the middle, and moved the remaining cards together. Now the Point IO...
676
Hi all, My name is Firdaus. I am a teacher. And for the next semester I have to teach PLC to student. The problem is, I just move to this school...
2,001
In RSLogix5000 I am attempting to create an add-on instruction called "SWAP" which simply swaps the values of two integer tags. Here is what the...
1,968
Hello all, I have a project that I need to remove so I can restore a newer version on to the machine (win7). When I use the application manager...
1,166
