How implement a timmer???
gutierrj
Jun 2005
Hi I'm working with S7-300 with STL, my problem is the next one: I am trying to delay a loop, just I want to spend time maybe 20s, then make a loop. Here is the structure of my program. I hope u can help with this.
Thanks.
Next: T #counter
Open a DB
Read data
Make operations
DELAY
L #counter
LOOP Next
Try this within your code
L S5T#20S // LOAD 20 SEC
SD T1 // SD = ON DELAY TIMER/ T1 JUST FOR EXAMPLE
AN T1 // WHEN 20 SEC HASN'T EXPIRED
JC M001 // JUMP CONDITIONALLY TO LABEL
L #counter
LOOP Next
M001:NOP 0
Regards
Hi I'm working with S7-300 with STL, my problem is the next one: I am trying to delay a loop, just I want to spend time maybe 20s, then make a...
2,812
Let's say I have an inverter fed three phase induction motor drive where in the braking phase (when the motor operates in a generator mode) the...
144
I want to improve a semi custom product I am delivering to a customer with implementation of safety relays. The system is fairly simple with just...
589
I'm struggling to implement the test case which is highlighted. What ends up happening is the servo starts when I turn the cycle on, but it...
1,075
I am trying to implement FIFO for filling tanks in the order it went empty in easysoft or some of you might know it by easydoft 7. I am trying to...
2,318
